Datasheet Texas Instruments SN74AUC1G07YZPR — Даташит
СерияSN74AUC1G07
МодельSN74AUC1G07YZPR
Одиночный буфер/драйвер с выходом с открытым стоком 5-DSBGA от -40 до 85
SN74AUC1G07 Single Buffer/Driver With Open-Drain Output datasheet
PDF, 986 Кб, Версия: R, Файл опубликован: 13 июн 2017
37 предложений от 17 поставщиков
Интегральные микросхемы Логические микросхемы - Буферы, Приемники, Приемопередатчики
Рутоника
SN74AUC1G07YZPR
13 ₽
SN74AUC1G07YZPR
20 ₽
SN74AUC1G07YZPR
727GS
SN74AUC1G07YZPR
Pin5
Package TypeYZP
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
МаркировкаUVN
Width (мм)1.25
Length (мм)1.75
Thickness (мм).31
Pitch (мм).5
Max Height (мм).5
3-State OutputNo
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeOPEN DRAIN BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupDSBGA
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)4.7,3.3,2.4,2.3,1.8 нс
  • Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)
    PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
    Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC1G07YZPR
