Datasheet Texas Instruments SN74AUC1G07DCKT — Даташит
СерияSN74AUC1G07
МодельSN74AUC1G07DCKT
Одиночный буфер/драйвер с выходом с открытым стоком 5-SC70 от -40 до 85
SN74AUC1G07 Single Buffer/Driver With Open-Drain Output datasheet
PDF, 986 Кб, Версия: R, Файл опубликован: 13 июн 2017
32 предложений от 20 поставщиков
Интегральные микросхемы Логические микросхемы - Буферы, Приемники, Приемопередатчики
SN74AUC1G07DCKT
76 ₽
SN74AUC1G07DCKT
от 80 ₽
SN74AUC1G07DCKT
241 ₽
Контест
SN74AUC1G07DCKT
Pin555
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY250250250
CarrierSMALL T&RSMALL T&RSMALL T&R
МаркировкаUVFUV5UVR
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeOPEN DRAIN BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)4.7,3.3,2.4,2.3,1.8 нс
  • Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)
    PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
    Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC1G07DCKT
