Datasheet Texas Instruments SN74AUC1G07DBVR — Даташит
Серия | SN74AUC1G07 |
Модель | SN74AUC1G07DBVR |
Одиночный буфер/драйвер с выходом с открытым стоком 5-SOT-23 от -40 до 85
SN74AUC1G07 Single Buffer/Driver With Open-Drain Output datasheet
PDF, 986 Кб, Версия: R, Файл опубликован: 13 июн 2017
Pin | 5 | 5 |
Package Type | DBV | DBV |
Industry STD Term | SOT-23 | SOT-23 |
Package QTY | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | U07F | U07R |
Width (мм) | 1.6 | 1.6 |
Length (мм) | 2.9 | 2.9 |
Thickness (мм) | 1.2 | 1.2 |
Pitch (мм) | .95 | .95 |
Max Height (мм) | 1.45 | 1.45 |
3-State Output | No |
Bits | 1 |
F @ Nom Voltage(Max) | 250 Mhz |
Gate Type | OPEN DRAIN BUFFER |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | True |
Output Drive (IOL/IOH)(Max) | 9/-9 мА |
Package Group | SOT-23 |
Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | IOFF,low power consumption,low tpd |
Sub-Family | Non-Inverting Buffer/Driver |
Technology Family | AUC |
VCC(Max) | 2.7 В |
VCC(Min) | 0.8 В |
Voltage(Nom) | 0.8,1.2,1.5,1.8,2.5 В |
tpd @ Nom Voltage(Max) | 4.7,3.3,2.4,2.3,1.8 нс |
- Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa - Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUC1G07 (9)
- Semiconductors > Logic > Little Logic
