Datasheet Texas Instruments SN74AUC1G14YZPR — Даташит
СерияSN74AUC1G14
МодельSN74AUC1G14YZPR
Инвертор с одним триггером Шмитта 5-DSBGA от -40 до 85
SN74AUC1G14 Single Schmitt-Trigger Inverter datasheet
PDF, 992 Кб, Версия: P, Файл опубликован: 8 июн 2017
Pin5
Package TypeYZP
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
МаркировкаUFN
Width (мм)1.25
Length (мм)1.75
Thickness (мм).31
Pitch (мм).5
Max Height (мм).5
3-State OutputNo
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeSCHMITT TRIGGER INVERTER
ICC @ Nom Voltage(Max)0.01 мА
LogicInverting
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupDSBGA
Schmitt TriggerYes
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyInverting Buffer/Driver
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)5.8,4,2.3,1.9,1.6 нс
  • Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)
    PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
    Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC1G14YZPR
