Datasheet Texas Instruments SN74AUC1G17DBVR — Даташит
СерияSN74AUC1G17
МодельSN74AUC1G17DBVR
Одиночный буфер триггера Шмитта 5-SOT-23 от -40 до 85
SN74AUC1G17 Single Schmitt-Trigger Buffer datasheet
PDF, 1.1 Мб, Версия: O, Файл опубликован: 8 июн 2017
Pin5555
Package TypeDBVDBVDBVDBV
Industry STD TermSOT-23SOT-23SOT-23SOT-23
JEDEC CodeR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-G
Package QTY3000300030003000
CarrierLARGE T&RLARGE T&RLARGE T&RLARGE T&R
МаркировкаU17FU17RU175U17K
Width (мм)1.61.61.61.6
Length (мм)2.92.92.92.9
Thickness (мм)1.21.21.21.2
Pitch (мм).95.95.95.95
Max Height (мм)1.451.451.451.45
3-State OutputNo
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeSCHMITT TRIGGER BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerYes
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)5.7,3.9,2.1,1.9,1.5 нс
  • Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)
    PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
    Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC1G17DBVR
