Datasheet Texas Instruments SN74AUC1G19DBVR — Даташит
СерияSN74AUC1G19
МодельSN74AUC1G19DBVR
Декодер/демультиплексор 1 из 2 6-SOT-23 от -40 до 85
SN74AUC1G19 1-of-2 Decoder/Demultiplexer datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 8 июн 2017
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаU19R
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
3-State OutputNo
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeDECODER/DEMUX
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyDecoder/Encoder/Multiplexer
Technology FamilyAUC
VCC(Max)2.5 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)7.5,4.6,2.0,2.4,1.7 нс
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC1G19DBVR
