Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74AUC1G19DCKR — Даташит
СерияSN74AUC1G19
МодельSN74AUC1G19DCKR
Декодер/демультиплексор 1 из 2 6-SC70 от -40 до 85
SN74AUC1G19 1-of-2 Decoder/Demultiplexer datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 8 июн 2017
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаU5R
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeDECODER/DEMUX
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyDecoder/Encoder/Multiplexer
Technology FamilyAUC
VCC(Max)2.5 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)7.5,4.6,2.0,2.4,1.7 нс
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC1G19DCKR
