Datasheet Texas Instruments SN74AUC1G66DCKRE4 — Даташит
СерияSN74AUC1G66
МодельSN74AUC1G66DCKRE4
Одиночный двусторонний аналоговый переключатель 5-SC70 от -40 до 85
Single Bilateral Analog Switch--SN74AUC1G66 datasheet
PDF, 1.0 Мб, Версия: L, Файл опубликован: 10 авг 2009
IC SWITCH 1X1 SC70-5. 1 Circuit IC Switch 1:1 15Ohm SC-70-5. Interface - Analog Switches, Multiplexers, Demultiplexers
SN74AUC1G66DCKRE4
7.73 ₽
SN74AUC1G66DCKRE4
SUV System
SN74AUC1G66DCKRE4
SN74AUC1G66DCKRE4
Pin555
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаU6FU6RU65
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
Полоса частот500 МГц
Configuration1:1 SPST
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)2.7 В
Input/Output Continuous Current(Max)50 мА
Input/Output OFF-state Capacitance(Typ)3.5 пФ
Input/Output ON-state Capacitance(Typ)7 пФ
Количество каналов1
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)1 мкА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Ron(Max)15 Ohms
Ron(Typ)10 Ohms
Supply Current(Max)10 uA
Supply Range2.7 Max
VIH(Min)vcc*.65 В
VIL(Max)vcc*.35 В
Vdd(Max)2.7 В
Vdd(Min)0.8 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)
    PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
    Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
На английском языке: Datasheet Texas Instruments SN74AUC1G66DCKRE4
