Datasheet Texas Instruments SN74CB3Q3245GQNR — Даташит
СерияSN74CB3Q3245
МодельSN74CB3Q3245GQNR
SN74CB3Q3245 datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 20 ноя 2003
Pin20
Package TypeGQN
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
Width (мм)3
Length (мм)4
Thickness (мм).75
Max Height (мм)1
Рекомендуемая замена
ReplacementSN74CB3Q3245ZQNR
Replacement CodeP
Additional FeaturesIOFF
Approx. Price (US$)0.33 | 1ku
Bandwidth(MHz)500
ConfigurationSPST
ESD Charged Device Model(kV)1
ESD HBM(kV)2
ICC(Max)(uA)2000
Input/Ouput Voltage(Max)(V)5.5
Input/Output Continuous Current(Max)(mA)64
Number of Channels(#)8
Operating Temperature Range(C)-40 to 85
Package GroupBGA MICROSTAR JUNIOR
SSOP
TSSOP
TVSOP
VQFN
Package Size: mm2:W x L (PKG)20BGA MICROSTAR JUNIOR: 12 mm2: 3 x 4(BGA MICROSTAR JUNIOR)
20VQFN: 16 mm2: 3.5 x 4.5(VQFN)
20TVSOP: 32 mm2: 6.4 x 5(TVSOP)
20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)
20SSOP: 52 mm2: 6 x 8.65(SSOP)
Ron(Max)(Ohms)9
Ron(Typ)(Ohms)4.5
VCC(Max)(V)3.6
VCC(Min)(V)2.3
RoHSНе совместим
  • CBT-C, CB3T, and CB3Q Signal-Switch Families
    PDF, 584 Кб, Файл опубликован: 4 фев 2003
    Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot
  • Semiconductors > Switches and Multiplexers > Signal Switches > Digital Switch
На английском языке: Datasheet Texas Instruments SN74CB3Q3245GQNR
