Datasheet Texas Instruments SNJ54CBTD3384JT — Даташит
СерияSN54CBTD3384
МодельSNJ54CBTD3384JT
10-битные коммутаторы шины со сдвигом уровня 24-CDIP от -55 до 125
SN54CBTD3384, SN74CBTD3384 datasheet
PDF, 998 Кб, Версия: R, Файл опубликован: 15 янв 2004
Pin24242424
Package TypeJTJTJTJT
Industry STD TermCDIPCDIPCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-TR-GDIP-TR-GDIP-T
Package QTY1111
CarrierTUBETUBETUBETUBE
МаркировкаATSNJ54CBTD3384J5962-9752701QL
Width (мм)6.926.926.926.92
Length (мм)32323232
Thickness (мм)4.74.74.74.7
Pitch (мм)2.542.542.542.54
Max Height (мм)5.085.085.085.08
Количество каналов10
Package GroupCDIP
RatingMilitary
Ron(Max)7 Ohms
Ron(Typ)5 Ohms
Technology FamilyCBT
VCC(Max)5.5 В
VCC(Min)4.5 В
RoHSSee ti.com
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • Semiconductors > Space & High Reliability > Logic Products > Switches and Multiplexer > Signal Switch
На английском языке: Datasheet Texas Instruments SNJ54CBTD3384JT
