Datasheet Texas Instruments MPC100AU/2K5 — Даташит
СерияMPC100
МодельMPC100AU/2K5
Широкополосный видеомультиплексор 4X1, 14-SOIC
АЦП азиатских производителей
Pin14
Package TypeD
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • Multiplexer Data Acquisition System
    PDF, 71 Кб, Файл опубликован: 4 окт 2000
    Multiplexers have been used for acquisition of quasi-static signals for a long time. While these signals usually have a low bandwidth of only a few hertz, applications generally require that the multiplexer send each signal as fast as possible to the converter and that the signals be processed quickly. To ensure fast processing, such acquisition systems usually include a sense amplifier behind the
  • Macromodels for RF Op Amps Are a Powerful Design Tool
    PDF, 68 Кб, Файл опубликован: 2 окт 2000
    The macromodel for the Diamond Transistor OPA660 gives an example of the structure and performance of these new Spice models.
Серия: MPC100 (3)
  • Semiconductors > Switches and Multiplexers > Multiplexer/Demultiplexer (Mux/Demux) > Analog Mux/Demux
На английском языке: Datasheet Texas Instruments MPC100AU/2K5
