Datasheet Texas Instruments INA132PA — Даташит
СерияINA132
МодельINA132PA
Дифференциальный усилитель малой мощности с одним питанием 8-PDIP
Low Power, Single-Supply Difference Amplifier datasheet
PDF, 333 Кб, Файл опубликован: 27 сен 2000
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Рекомендуемая замена
ReplacementINA132UA
Replacement CodeF
Approx. Price (US$)1.15 | 1ku
CMRR(Min)(dB)76
Common Mode Input High(Max)(V)28
Common Mode Input High(Min)(V)28
Common Mode Input Low(Min)(V)-15
Gain Drift(Max)(ppm/C)1
Gain Error (+/-)(Max)(%)0.075
Gain(Max)(V/V)1
Gain(Min)(V/V)1
Gain(V/V)1
Input Offset (+/-)(Max)(uV)250
Input Offset Drift (+/-)(Max)(uV/C)5
Iq(Typ)(mA)0.16
Number of Channels(#)1
Operating Temperature Range(C)-40 to 85
Slew Rate(Typ)(V/us)0.1
Small Signal Bandwidth(Typ)(MHz)0.3
Vs(Max)(V)36
Vs(Min)(V)2.7
RoHSНе совместим
  • High-Voltage Signal Conditioning for Low Voltage ADCs
    PDF, 135 Кб, Файл опубликован: 15 июн 2004
    Analog designers are frequently required to develop circuits that convert high-voltage signals to levels acceptable for low-voltage data converters. This paper describes several solutions for this common task using modern amplifiers and typical power supplies. Five examples of conditioning ±10V bipolar signals for low-voltage single-rail analog-to-digital converters(ADCs) are presented:
  • Precision Absolute Value Circuits
    PDF, 100 Кб, Файл опубликован: 2 окт 2000
    You can build a precision absolute value circuit using two op amps and two precision resistors. If you use an op amp and an IC difference amplifier no user supplied precision resistors or resistor adjustments are required. Circuits shown are suitable for precision split supply operation and for single-supply operation. When used with a rail-to-rail op amp the single supply circuit can approach a
  • Semiconductors > Amplifiers > Special Function Amplifiers > Difference Amplifiers
На английском языке: Datasheet Texas Instruments INA132PA
