Datasheet Texas Instruments LM134H — Даташит
СерияLM134
МодельLM134H
3-контактный регулируемый источник тока 3-TO от -55 до 125
LM134/LM234/LM334 3-Terminal Adjustable Current Sources datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 20 июн 2013
Pin33
Package TypeNDVNDV
Industry STD TermTO-CANTO-CAN
JEDEC CodeO-MSFM-PO-MSFM-P
Package QTY10001000
МаркировкаLM134HLM134H
Width (мм)4.6994.699
Length (мм)4.6994.699
Thickness (мм)2.3622.362
Max Height (мм)2.6672.667
RoHSSee ti.com
  • LB-41 Precision Reference Uses Only Ten Microamperes (Rev. B)
    PDF, 70 Кб, Версия: B, Файл опубликован: 3 май 2013
    This application report discusses how a precision reference uses only 10 microamperes.
  • AN-211 New Op Amp Ideas (Rev. A)
    PDF, 1.4 Мб, Версия: A, Файл опубликован: 6 май 2013
    An op amp and voltage reference capable of single supply operation down to 1.1V is introduced.Performance is uncompromised and compares favorably with standard, state-of-the-art devices. In adeparture from conventional approaches, the circuit can operate in a floating mode, powered by residualvoltages, independent of fixed supplies. A brief description of the IC design is given, but emphasis
  • AN-460 LM34/LM35 Precision Monolithic Temperature Sensors (Rev. C)
    PDF, 495 Кб, Версия: C, Файл опубликован: 1 май 2013
    This application report discusses the details and uses of the Texas Instruments LM34 and LM35 asprecision temperature sensors.
Серия: LM134 (3)
  • Semiconductors > Space & High Reliability > Power Management Products > Voltage Reference Products
На английском языке: Datasheet Texas Instruments LM134H
