Datasheet Texas Instruments SN74AVCA406DGGR — Даташит
СерияSN74AVCA406
МодельSN74AVCA406DGGR
Приемопередатчик преобразования напряжения MMC, SD, Memory Stick, Smart Media и XD-Picture Card 48-TSSOP от -40 до 85
+/-15 kV ESD-Protected Voltage-Translation Transceiver datasheet
PDF, 2.8 Мб, Версия: H, Файл опубликован: 26 янв 2007
32 предложений от 17 поставщиков
Микросхема Логический контроллер, MMC, SD, Memory Stick, Smart Media, and XD-Picture Card Voltage Translation Transceiver 48-TSSOP -40℃ to 85℃
Рутоника
SN74AVCA406DGGR
85 ₽
SN74AVCA406DGGR
121 ₽
SN74AVCA406DGGR
121 ₽
SN74AVCA406DGGR
123 ₽
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаAVCA406
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits18
ICCA Static Current0.01 мА
ICCB Static Current0.01 мА
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
Special FeaturesSD/SDIO/MMC Card
Static Current0.02 мА
VCCA(Max)3.6 В
VCCA(Min)1.4 В
VCCB(Max)3.6 В
VCCB(Min)1.4 В
  • Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
    Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i
  • AVC Logic Family Technology and Applications (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
    Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control (
  • Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)
    PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74AVCA406 (3)
  • Semiconductors > Logic > Voltage Level Translation > Application Specific Voltage Translation
На английском языке: Datasheet Texas Instruments SN74AVCA406DGGR
