Datasheet Texas Instruments CD74HCT40103EE4 — Даташит
Серия | CD74HCT40103 |
Модель | CD74HCT40103EE4 |
Высокоскоростные КМОП-логики, 8-ступенчатые синхронные счетчики обратного счета, 16-PDIP, от -55 до 125
CD54HC40103, CD74HC40103, CD74HCT40103 datasheet
PDF, 460 Кб, Версия: D, Файл опубликован: 16 окт 2003
![]() 7 предложений от 7 поставщиков Микросхема Логический контроллер, Counter Single 8Bit Sync/Async Binary Down 16Pin PDIP Tube | |||
CD74HCT40103EE4 Texas Instruments | 45 ₽ | ||
CD74HCT40103EE4 Texas Instruments | 61 ₽ | ||
CD74HCT40103EE4 Texas Instruments | по запросу |
Pin | 16 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | CD74HCT40103E |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Bits | 8 |
F @ Nom Voltage(Max) | 25 Mhz |
Function | Counter |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 4/-4 мА |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rating | Catalog |
Technology Family | HCT |
Тип | Binary |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 85 нс |
Бессвинцовая технология (Pb Free) | Да |
- Wave Solder Exposure of SMT PackagesPDF, 206 Кб, Файл опубликован: 9 сен 2008
It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
Серия: CD74HCT40103 (6)
- CD74HCT40103E CD74HCT40103EE4 CD74HCT40103M CD74HCT40103M96 CD74HCT40103M96G4 CD74HCT40103MG4
- Semiconductors > Logic > Specialty Logic > Counter/Arithmetic/Parity Function
