Оптопары и оптореле Megawin
Datasheet Texas Instruments CLVTH16543MDLREP — Даташит
СерияSN74LVTH16543-EP
МодельCLVTH16543MDLREP
Усовершенствованный продукт 16-битный зарегистрированный трансивер с напряжением 3,3 В и выходами с 3 состояниями 56-SSOP от -55 до 125
SN74LVTH16543-EP datasheet
PDF, 298 Кб, Версия: B, Файл опубликован: 16 июн 2006
Pin56
Package TypeDL
Industry STD TermSSOP
Package QTY1000
МаркировкаLH16543MEP
Width (мм)7.49
Length (мм)18.41
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Bits16
Рабочий диапазон температурот -40 до 85,-55 до 125 C
Package GroupSSOP
Package Size: mm2:W x L56SSOP: 191 mm2: 10.35 x 18.42(SSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
На английском языке: Datasheet Texas Instruments CLVTH16543MDLREP
Публикации по теме
