Datasheet Texas Instruments SN74LVC1G66DSFR — Даташит
СерияSN74LVC1G66
МодельSN74LVC1G66DSFR
Одиночный аналоговый переключатель 6-SON от -40 до 85
SN74LVC1G66 Single Bilateral Analog Switch datasheet
PDF, 1.5 Мб, Версия: Q, Файл опубликован: 23 мар 2017
Pin6
Package TypeDSF
Industry STD TermX2SON
JEDEC CodeS-PDSO-N
Package QTY5000
МаркировкаC6
Width (мм)1
Length (мм)1
Thickness (мм).35
Pitch (мм).35
Max Height (мм).4
Полоса частот300 МГц
Configuration1:1 SPST
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)50 мА
Input/Output OFF-state Capacitance(Typ)6 пФ
Input/Output ON-state Capacitance(Typ)13 пФ
Количество каналов1
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)1 мкА
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Ron(Max)120 Ohms
Ron(Typ)7.5 Ohms
Supply Current(Max)10 uA
Supply Current(Typ)1 uA
Supply Range5.5 Max
VIH(Min)vcc*.7 В
VIL(Max)vcc*.3 В
Vdd(Max)5.5 В
Vdd(Min)1.65 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Development Kits: DLPLIGHTCRAFTER
    DLPВ® LightCrafterВ™ Evaluation Module
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
На английском языке: Datasheet Texas Instruments SN74LVC1G66DSFR
