Datasheet Texas Instruments 5962-0051206QHA — Даташит
Серия | TLV2462AM |
Модель | 5962-0051206QHA |
Двойной маломощный операционный усилитель ввода-вывода с Rail-to-Rail, 10-CFP от -55 до 125
Datasheet
Pin | 10 | 10 |
Package Type | U | U |
Industry STD Term | CFP | CFP |
JEDEC Code | S-GDFP-F | S-GDFP-F |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | TLV2462AM | 0051206QHA |
Width (мм) | 6.35 | 6.35 |
Length (мм) | 6.35 | 6.35 |
Thickness (мм) | 1.65 | 1.65 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 |
Approx. price | 19.617 | 100u US$ |
Архитектура | Bipolar |
CMRR(Min) | 71 дБ |
CMRR(Typ) | 85 дБ |
Основные особенности | N/A |
GBW(Typ) | 6.4 МГц |
Input bias current(Max) | 14000 pA |
Input bias current(Typ) | 1300 pA |
Iq per channel(Max) | 0.65 мА |
Iq per channel(Typ) | 0.55 мА |
Number of channels | 2 |
Offset drift(Typ) | 2 uV/C |
Operating temperature range | -55 to 125 C |
Output current(Typ) | 80 мА |
Output swing headroom (to negative supply)(Typ) | 0.2 В |
Output swing headroom (to positive supply)(Typ) | -0.2 В |
Package Group | CDIP|8,CFP|10,LCCC|20 |
Package size: mm2:W x L | 8CDIP: 64 mm2: 6.67 x 9.6 (CDIP|8),10CFP: 40 mm2: 6.35 x 6.35 (CFP|10),20LCCC: 79 mm2: 8.89 x 8.89 (LCCC|20) PKG |
Rail-to-rail | In,Out |
Rating | Catalog,Military |
Slew rate(Typ) | 1.6 V/us |
Total supply voltage(Max) | 6 +5V=5, +/-5V=10 |
Total supply voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1 kHz(Typ) | 11 нВ/rtГц |
Vos (offset voltage @ 25 C)(Max) | 1.5 мВ |
RoHS | Не совместим |
Бессвинцовая технология (Pb Free) | Да |
Серия: TLV2462AM (7)
- 5962-0051206Q2A 5962-0051206QHA 5962-0051206QPA TLV2462AMFKB TLV2462AMJG TLV2462AMJGB TLV2462AMUB
- Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational amplifiers (op amps) > General-purpose op amps
59620051206QHA, 5962 0051206QHA
