Datasheet Texas Instruments TMS320F28333PGFA — Даташит
СерияTMS320F28333
МодельTMS320F28333PGFA
Контроллеры цифровых сигналов 176-LQFP от -40 до 85
TMS320F2833x, TMS320F2823x Digital Signal Controllers (DSCs) datasheet
PDF, 2.9 Мб, Версия: N, Файл опубликован: 18 окт 2016
27 предложений от 15 поставщиков
IC MCU 32BIT 512KB FLASH. C28x C2000TM C28x DelfinoTM Microcontroller IC 32-Bit 100MHz 512KB (256K x 16) FLASH 176-LQFP...
TMS320F28333PGFA
521 ₽
Зенер
Россия и страны ТС
TMS320F28333PGFA
от 1 186 ₽
Microfind
TMS320F28333PGFA
1 568 ₽
Hi-Tech Circuit Group
TMS320F28333PGFA
Pin176176
Package TypePGFPGF
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY4040
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаTMS320F28333PGFA
Width (мм)2424
Length (мм)2424
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
ADC16 Ch
ADC Resolution12-bit
CAN2
CPUC28x
DMA6 Ch
EMIF1 32/16-Bit
FPUYes
Flash512 KB
Тактовая частота100 МГц
High Resolution PWM6 Ch
I2C1
McBSP2
PWM12 Ch
Pin/Package176LQFP
QEP2
RAM68 KB
SPI1
Security EnablerDebug security,Software IP protection
Total Processing100 MIPS
UART3 SCI
  • Development Kits: TMDSEZ28335
    TMS320F28335 eZdsp Starter Kit
  • Daughter Cards: TMDSCNCD28335
    TMS320F28335 controlCARD
  • Development Kits: TMDSDOCK28335
    TMS320F28335 Experimenter Kit
  • Evaluation Modules & Boards: TMDSHVMTRPFCKIT
    High Voltage Motor Control and PFC Developer's Kit
  • Programming Examples for the TMS320x28xx eCAN (Rev. B)
    PDF, 73 Кб, Версия: B, Файл опубликован: 12 сен 2017
    The TMS320x28xx series of Microcontrollers/Digital Signal Controllers feature an on-chip enhanced Controller Area Network (eCAN) module. This module is a full-CAN controller, compliant with CAN specification 2.0B. This application report contains several programming examples, supplemental to those in C2000Ware/controlSUITE, to illustrate how the eCAN module is set up for different modes of operati
Серия: TMS320F28333 (1)
  • TMS320F28333PGFA
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Delfino F2833x/F2837x
На английском языке: Datasheet Texas Instruments TMS320F28333PGFA
