Datasheet Texas Instruments DRV10983ZPWP — Даташит
СерияDRV10983
МодельDRV10983ZPWP
40 Вт, 24 В, 3-фазный бездатчиковый драйвер двигателя BLDC 24-HTSSOP от -40 до 125
DRV10983 12- to 24-V, Three-Phase, Sensorless BLDC Motor Driver datasheet
PDF, 1.9 Мб, Версия: E, Файл опубликован: 16 май 2017
IC MOTOR DRIVER 8V-28V 24HTSSOP. Motor Driver Power MOSFET Analog, I²C, PWM 24-HTSSOP. PMIC - Motor Drivers, Controllers
DRV10983ZPWP
216 ₽
Рутоника
DRV10983ZPWP
261 ₽
DRV10983ZPWP
317 ₽
DRV10983ZPWP
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY60
МаркировкаDRV10983Z
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Additional Features180 Degree Sinusoidal Commutation,100mA Step Down Buck,Rotor Lock Protection
Control I/FPWM, Analog, or I2C
Number of Half Bridges3
Package GroupHTSSOP
Peak Output Current3 A
RDS(ON) (HS + LS)250 mOhms
RMS Output Current2 A
Vs(Max)28 В
Vs(Min)8 В
  • Evaluation Modules & Boards: DRV10983EVM-TB
    DRV10983EVM Target Board
    DRV10983 Three-Phase Brushless Motor Driver Evaluation Module
  • Speed-Control Techniques in AC-DC Operated BLDC Applications
    PDF, 165 Кб, Файл опубликован: 11 авг 2016
    To achieve energy efficiency, ceiling fans and ventilation fans are moving from simple alternate-current (AC) induction motors to brushless direct-current (DC) motors (BLDC). An AC-operated BLDC motor requires two sections to run the BLDC motor: the AC-DC power conversion section and the DC to 3-phase AC conversion section. The Texas Instruments reference design, TIDA-00652, helps to meet these ch
  • DRV10983EVM-TB Target Board Programming Guide
    PDF, 398 Кб, Файл опубликован: 7 окт 2014
    DRV10983/DRV10975 Programming Guide for the DRV10983/DRV10975
Серия: DRV10983 (4)
  • Semiconductors > Motor Drivers > Brushless DC (BLDC) Drivers > Brushless DC Drivers with FETs
На английском языке: Datasheet Texas Instruments DRV10983ZPWP
