Datasheet ТI TXS0108EPWRG4 — Даташит
СерияTXS0108E
МодельTXS0108EPWRG4
Datasheet Texas Instruments TXS0108EPWRG4
8-битный двунаправленный преобразователь уровня напряжения для приложений с открытым стоком и двухтактной схемы 20-TSSOP от -40 до 85
TXS0108E 8-Bit Bi-directional, Level-Shifting, Voltage Translator for Open-Drain and Push-Pull Applications datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 22 фев 2016
  • Effects of pullup and pulldown resistors on TXS and TXB devices
    PDF, 732 Кб, Файл опубликован: 20 сен 2017
    The TXS and TXB family of devices belong to the auto-bidirectional translation products from TI. These devices can be sensitive to external pullup or pulldown resistors due to the internal pullup resistors present in the TXS device and the internal serial resistors present in the TXB device. In this application note, the effects of external pullup and pulldown resistors on VOL and VOH levels of th
  • A Guide to Voltage Translation With TXS-Type Translators
    PDF, 287 Кб, Файл опубликован: 29 июн 2010
    Modern trends are driving the need for lower supply voltages across many system-level designs. As most processor voltage levels continue to decrease in the interest of achieving the lowest possible power consumption, peripheral devices maintain a need for higher voltage levels, creating potential for voltage discontinuities within a system. To remedy this mixed voltage system incompatibility, a vo
Серия: TXS0108E (4)
  • Semiconductors > Logic > Voltage Level Translation > Bidirectional Voltage Translation
На английском языке: Datasheet Texas Instruments TXS0108EPWRG4
Политика конфиденциальности
