Datasheet Texas Instruments 5962-86828012A — Даташит
СерияSN54HC366
Модель5962-86828012A
Драйверы шестнадцатеричной шины с выходами с 3 состояниями 20-LCCC от -55 до 125
Hex Bus Drivers With 3-State Outputs datasheet
PDF, 1.2 Мб, Файл опубликован: 1 июн 1989
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Operating Temperature Range(C)-55 to 125
Package GroupCDIP
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
RoHSНе совместим
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Introduction to Logic
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
596286828012A, 5962 86828012A
На английском языке: Datasheet Texas Instruments 5962-86828012A
