Datasheet Texas Instruments DRV8701ERGER — Даташит
СерияDRV8701
МодельDRV8701ERGER
Драйвер коллекторного двигателя постоянного тока (PH/EN, PWM Ctrl) 24-VQFN от -40 до 125
DRV8701 Brushed DC Motor Full-Bridge Gate Driver datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 июл 2015
Pin24
Package TypeRGE
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Маркировка8701E
Width (мм)4
Length (мм)4
Thickness (мм).88
Pitch (мм).5
Max Height (мм)1
Additional FeaturesAdjustable Gate Drive Settings,3.3V/5V LDO,Integrated Current Shunt Amplifier,Low-Power Sleep Mode
Control I/FPHASE/ENABLE,PWM
Peak Output Sink Current Gate Drive(Max)0.3 A
Peak Output Source Current Gate Drive(Max)0.15 A
Vs(Max)45 В
Vs(Min)5.9 В
  • Evaluation Modules & Boards: DRV8701EVM
    DRV8701 Full Bridge Brushed DC Motor Gate Driver Evaluation Module
  • Understanding IDRIVE and TDRIVE in TI Motor Gate Drivers (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 11 май 2016
    The motor gate driver is an integrated circuit (IC) that primarily deals with enhancing external power MOSFETs to drive an electric motor. The gate driver acts as an intermediate stage between the logic-level control inputs and the power MOSFETs. The gate driver must be flexible enough to accommodate a wide variety of external MOSFETs and external system conditions.Texas Instrument’s IDRIVE
Серия: DRV8701 (4)
  • Semiconductors > Motor Drivers > Brushed DC (BDC) Drivers > Brushed DC Gate Drivers
На английском языке: Datasheet Texas Instruments DRV8701ERGER
