Datasheet Texas Instruments SN74AVCBH164245KR — Даташит
СерияSN74AVCBH164245
МодельSN74AVCBH164245KR
16-битная шина Xcvr с двойным питанием и конфигурацией.
16-Bit Dual-Supply Bus Transceiver datasheet
PDF, 895 Кб, Версия: B, Файл опубликован: 28 мар 2008
Расширение напряжения и выходы с 3 состояниями 56-BGA MICROSTAR JUNIOR от -40 до 85
Pin56
Package TypeGQL
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
МаркировкаWBH4245
Width (мм)4.5
Length (мм)7
Thickness (мм).75
Max Height (мм)1
Рекомендуемая замена
Replacement74AVCBH164245ZQLR
Replacement CodeP
Approx. Price (US$)1.86 | 1ku
Bits(#)16
ICCA Static Current(mA)0.04
ICCB Static Current(mA)0.04
Operating Temperature Range(C)-40 to 85
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L (PKG)56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR)
VCCA(Max)(V)3.3
VCCA(Min)(V)2.5
VCCB(Max)(V)5
VCCB(Min)(V)3.3
RoHSНе совместим
  • Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)
    PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
    Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i
  • AVC Logic Family Technology and Applications (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
    Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control (
  • Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)
    PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Semiconductors > Logic > Voltage Level Translation > Application Specific Voltage Translation
На английском языке: Datasheet Texas Instruments SN74AVCBH164245KR
