Datasheet Texas Instruments THS5651AIDW — Даташит
СерияTHS5651A
МодельTHS5651AIDW
10-битный цифро-аналоговый преобразователь (ЦАП) с быстродействием 125 MSPS, 28-SOIC, от -40 до 85
10-Bit 125 MSPS CommsDAC datasheet
PDF, 948 Кб, Версия: A, Файл опубликован: 25 сен 2002
Pin28
Package TypeDW
Package QTY20
МаркировкаTHS5651AI
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
АрхитектураCurrent Source
DAC Channels1
InterfaceParallel CMOS
Interpolation1x
Package Size: mm2:W x L28SOIC: 184 mm2: 10.3 x 17.9(SOIC) PKG
Power Consumption(Typ)175 mW
Разрешение10 Bits
SFDR61 дБ
Sample / Update Rate125 MSPS
  • Evaluation Modules & Boards: THS5651EVM
    THS5651A 10-Bit, 125-MSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments THS5651AIDW
