Datasheet Texas Instruments SN74HC164DT — Даташит
Серия | SN74HC164 |
Модель | SN74HC164DT |
8-битные сдвиговые регистры последовательного вывода с параллельным выходом 14-SOIC от -40 до 125
SNx4HC164 8-Bit Parallel-Out Serial Shift Registers datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 3 фев 2014
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | HC164 |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
3-State Output | No |
F @ Nom Voltage(Max) | 28 Mhz |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 5.2/-5.2 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | HC |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 6 В |
tpd @ Nom Voltage(Max) | 38 нс |
- HCMOS Design Considerations (Rev. A)PDF, 207 Кб, Версия: A, Файл опубликован: 9 сен 2002
This document describes a potential problem designers may encounter when using high-speed CMOS (HC) logic devices. There also is a broad range of CMOS-system to non-CMOS-system interfaces that need to be considered. The design engineer inevitably encounters these interfaces. Key considerations for handling these interfaces are also discussed in this book.
Серия: SN74HC164 (19)
- Semiconductors > Logic > Flip-Flop/Latch/Register > Shift Register
