Datasheet Texas Instruments SNJ54AHC138J — Даташит
СерияSN54AHC138
МодельSNJ54AHC138J
Декодеры/демультиплексоры с 3-8 строками 16-CDIP от -55 до 125
SN54AHC138, SN74AHC138 datasheet
PDF, 1.3 Мб, Версия: L, Файл опубликован: 2 июл 2003
АЦП азиатских производителей
Pin161616
Package TypeJJJ
Industry STD TermCDIPCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-TR-GDIP-T
Package QTY111
CarrierTUBETUBETUBE
Маркировка5962-9851601QEASNJ54AHC138J
Width (мм)6.926.926.92
Length (мм)19.5619.5619.56
Thickness (мм)4.574.574.57
Pitch (мм)2.542.542.54
Max Height (мм)5.085.085.08
Количество каналов1
F @ Nom Voltage(Max)110 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyAHC
VCC(Max)5.5 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)13,9.5 нс
RoHSSee ti.com
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
На английском языке: Datasheet Texas Instruments SNJ54AHC138J
