Datasheet Texas Instruments 5962-0924001VXC — Даташит
СерияADS5400-SP
Модель5962-0924001VXC
12-разрядный аналого-цифровой преобразователь (АЦП) 1,0-GSPS 100-CFP от -55 до 125
12-Bit, 1-GSPS Analog-to-Digital Converter. datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 2 янв 2014
Pin100
Package TypeHFS
Industry STD TermCFP (TBAR)
JEDEC CodeS-CQFP-F
Package QTY1
Width (мм)19.05
Length (мм)19.05
Thickness (мм)2.82
Pitch (мм)0.5
Max Height (мм)3.15
# Input Channels1
Analog Voltage AVDD(Max)3.465 В
Analog Voltage AVDD(Min)3.135 В
АрхитектураPipeline
Digital Supply(Max)3.465 В
Digital Supply(Min)3.135 В
ENOB9.2 Bits
INL(Max)4.5 +/-LSB
INL(Typ)1.5 +/-LSB
InterfaceParallel LVDS
Рабочий диапазон температурот -55 до 125,25 Only C
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
Power Consumption(Typ)2200 mW
RatingSpace
Reference ModeExt,Int
Разрешение12 Bits
SFDR72 дБ
SNR58.5 дБ
RoHSSee ti.com
  • Evaluation Modules & Boards: ADS5400EVM-CVAL
    ADS5400-SP Evaluation Module
    ADS5400 12-bit; 1.0-GSPS Analog-to-Digital Converter Evaluation Module
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • CDCE62005 as Clock Solution for High-Speed ADCs
    PDF, 805 Кб, Файл опубликован: 4 сен 2008
    TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
Серия: ADS5400-SP (3)
  • Semiconductors > Space & High Reliability > Data Converter > Analog to Digital Converters
59620924001VXC, 5962 0924001VXC
На английском языке: Datasheet Texas Instruments 5962-0924001VXC
