Datasheet Texas Instruments 7604101EA — Даташит
| Серия | SN54S138 |
| Модель | 7604101EA |
Декодеры/демультиплексоры с 3-8 строками 16-CDIP от -55 до 125
3-Line To 8-Line Decoders/Demultiplexers datasheet
PDF, 1.2 Мб, Файл опубликован: 1 мар 1988
Купить 7604101EA на РадиоЛоцман.Цены — от 1 368 до 1 698 ₽9 предложений от 9 поставщиков Микросхема Логический контроллер, Decoder/Demultiplexer Single 3-to-8 16Pin CDIP Tube | |||
| 7604101EA Texas Instruments | 1 368 ₽ | ||
| 7604101EA Texas Instruments | по запросу | ||
| 7604101EA/SNJ Texas Instruments | по запросу | ||
| Pin | 16 | 16 |
| Package Type | J | J |
| Industry STD Term | CDIP | CDIP |
| JEDEC Code | R-GDIP-T | R-GDIP-T |
| Package QTY | 1 | 1 |
| Carrier | TUBE | TUBE |
| Маркировка | 7604101EA | SNJ54S138J |
| Width (мм) | 6.92 | 6.92 |
| Length (мм) | 19.56 | 19.56 |
| Thickness (мм) | 4.57 | 4.57 |
| Pitch (мм) | 2.54 | 2.54 |
| Max Height (мм) | 5.08 | 5.08 |
| RoHS | See ti.com |
- Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Серия: SN54S138 (9)
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
