Datasheet Texas Instruments DAC3282IRGZT — Даташит
СерияDAC3282
МодельDAC3282IRGZT
Двухканальный, 16-битный, 625-MSPS, 1x-2x интерполяционный цифро-аналоговый преобразователь (ЦАП) 48-VQFN от -40 до 85
DAC3282 16-Bit, 625 MSPS, 2x Interpolating, Dual-Channel Digital-to-Analog Converter (DAC) datasheet
PDF, 2.1 Мб, Версия: C, Файл опубликован: 31 мар 2015
Микросхема Преобразователь DA, Dual-Channel, 16Bit, 625MSPS, 1x-2x Interpolating Digital-to-Analog Converter (DAC) 48-VQFN -40℃ to 85℃
DAC3282IRGZT
1 925 ₽
Рутоника
DAC3282IRGZT
2 504 ₽
DAC3282IRGZT
3 056 ₽
DAC3282IRGZT
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаDAC3282I
Width (мм)7
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
АрхитектураCurrent Sink
DAC Channels2
InterfaceParallel LVDS
Interpolation1x,2x
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 49 mm2: 7 x 7(VQFN) PKG
Power Consumption(Typ)950 mW
Разрешение16 Bits
SFDR83 дБ
Sample / Update Rate625 MSPS
  • Evaluation Modules & Boards: DAC3282EVM
    DAC3282 Evaluation Module
  • Evaluation Modules & Boards: TSW1406EVM
    Pattern Generator: Data Converter EVMs With 8 LVDS Lanes up to 1.0Gbps
  • Evaluation Modules & Boards: FMC-DAC-ADAPTER
    High Speed DAC to FMC (Xilinx) Header Adapter Card
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Design of Differential Filters for High-Speed Signal Chains (Rev. B)
    PDF, 166 Кб, Версия: B, Файл опубликован: 30 апр 2010
    Differential filters have many desirable attributes. The task of designing differential filters can seem daunting at first. Single-ended filters designed in any filter design package can be converted to a differential implementation. This application report explores simple conversion techniques for low-pass, high-pass, and band-pass LC filters.
  • DAC348x Device Configuration and Synchronization
    PDF, 317 Кб, Файл опубликован: 18 фев 2013
  • Interfacing op amps to high-speed DACs, Part 1: Current-sinking DACs
    PDF, 319 Кб, Файл опубликован: 14 июл 2009
  • Interfacing op amps to high-speed DACs, Part 2: Current-sourcing DACs
    PDF, 617 Кб, Файл опубликован: 4 окт 2009
  • Passive Terminations for Current Output DACs
    PDF, 244 Кб, Файл опубликован: 10 ноя 2008
    The correct implementation of the high-speed DAC output termination is critical to achieving the best possible performance. The typical application involves choosing the correct network to create the necessary dc bias levels and correct effective impedance load to keep the output voltage within the compliance levels. This ensures that the maximum output signal amplitude and optimum ac performance
  • Q3 2009 Issue Analog Applications Journal
    PDF, 2.1 Мб, Файл опубликован: 14 июл 2009
  • Q4 2009 Issue Analog Applications Journal
    PDF, 1.5 Мб, Файл опубликован: 4 окт 2009
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
Серия: DAC3282 (2)
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments DAC3282IRGZT
