Datasheet Texas Instruments LM741C-MWC — Даташит
Серия | LM741 |
Модель | LM741C-MWC |
Операционный усилитель 0-WAFERSALE -40 до 85
LM741 Operational Amplifier datasheet
PDF, 688 Кб, Версия: D, Файл опубликован: 30 окт 2015
Package Type | YS |
Package QTY | 1 |
Additional Features | N/A |
Архитектура | Bipolar |
CMRR(Min) | 70 дБ |
CMRR(Typ) | 90 дБ |
GBW(Typ) | 1 МГц |
Input Bias Current(Max) | 210000 pA |
Iq per channel(Max) | 2.8 мА |
Iq per channel(Typ) | 1.7 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 15 uV/C |
Рабочий диапазон температур | от -40 до 85,0 до 70 C |
Output Current(Typ) | 25 мА |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rating | Catalog |
Slew Rate(Typ) | 0.5 V/us |
Total Supply Voltage(Max) | 44 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 10 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 30 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 3 мВ |
- AN-71 Micropower Circuits Using the LM4250 Programmable Op Amp (Rev. B)PDF, 536 Кб, Версия: B, Файл опубликован: 1 май 2013
This application report describes the circuit operation of the Texas Instruments LM4250, various methodsof biasing the device, frequency response considerations, and some circuit applications exercising theunique characteristics of the LM4250. - Predicting Op Amp Slew Rate Limited ResponsePDF, 139 Кб, Файл опубликован: 7 окт 2002
- AN-79 IC Preamplifier Challenges Choppers on Drift (Rev. B)PDF, 940 Кб, Версия: B, Файл опубликован: 1 май 2013
Since the introduction of monolithic IC amplifiers there has been a continual improvement in DC accuracy.Bias currents have been decreased by 5 orders of magnitude over the past 5 years. Low offset voltagedrift is also necessary in a high accuracy circuits. This is evidenced by the popularity of low drift amplifiertypes as well as the requests for selected low-drift op amps. However until n - Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits. - Low Drift AmplifiersPDF, 71 Кб, Файл опубликован: 2 окт 2002
- LM143 Monolithic High Voltage Operational Amplifier ApplicationsPDF, 479 Кб, Файл опубликован: 2 май 2004
Application Note 127 LM143 Monolithic High Voltage Operational Amplifier Applications - AN-480 A 40 MHz Programmable Video Op AmpPDF, 218 Кб, Файл опубликован: 11 май 2004
- Get Fast Stable Response From Improved Unity-Gain FollowersPDF, 107 Кб, Файл опубликован: 2 окт 2002
- AN-711 LM78S40 Switching Voltage Regulator Applications (Rev. B)PDF, 740 Кб, Версия: B, Файл опубликован: 7 май 2013
This application note describes a new integrated subsystem that contains the control circuitry, as well asthe switching elements, required for constructing switching regulator systems. - LM118 Op Amp Slews 70 V/secPDF, 118 Кб, Файл опубликован: 1 окт 2002
LM118 Op Amp Slews 70 V/ГѓВґsec
Серия: LM741 (3)
- LM741C-MWC LM741CN/NOPB U9T7741393
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
LM741CMWC, LM741C MWC
