Datasheet Texas Instruments OPA2234MDR — Даташит
Серия | OPA2234M |
Модель | OPA2234MDR |
Маломощные прецизионные операционные усилители с однополярным питанием 8-SOIC от -55 до 125
Low-Power, Precision Single-Supply Operational Amplifiers- datasheet
PDF, 963 Кб, Файл опубликован: 25 фев 2011
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2234M |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | Bipolar |
CMRR(Min) | 86 дБ |
CMRR(Typ) | 106 дБ |
GBW(Typ) | 0.35 МГц |
IIB(Max) | 25000 pA |
Iq per channel(Max) | 0.3 мА |
Iq per channel(Typ) | 0.25 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 3 uV/C |
Output Current(Typ) | 11 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Military |
Slew Rate(Typ) | 0.2 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 25 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.1 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2234M (1)
- OPA2234MDR
- Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
