Datasheet Texas Instruments V62/12603-01XE — Даташит
СерияTPS61222-EP
МодельV62/12603-01XE
Enhanced Product Low Input Voltage, 0.7V, Boost Converter with 5.5ОјA Quiescent Current 6-SC70 -55 to 125
Low Input Voltage, 0.7V, Boost Converter With 5.5ОјA Quiescent Current . datasheet
PDF, 956 Кб, Файл опубликован: 25 сен 2012
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY250
CarrierSMALL T&R
МаркировкаSHL
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Duty Cycle(Max)90 %
Iq(Typ)0.005 мА
Package GroupSC70
RatingHiRel Enhanced Product
Regulated Outputs1
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)0.7 В
Vout(Max)5 В
Vout(Min)5 В
  • Evaluation Modules & Boards: TPS61220EVM-319
    TPS61220EVM-319 Evaluation Module
Серия: TPS61222-EP (2)
  • Semiconductors > Space & High Reliability > Power Management Products > Non-isolated DC/DC Switching Regulators
V62/1260301XE, V62/12603 01XE
На английском языке: Datasheet Texas Instruments V62/12603-01XE
