Datasheet Texas Instruments TMS320C52PJ57 — Даташит
СерияTMS320C52
МодельTMS320C52PJ57
14 предложений от 14 поставщиков
Цифровой сигнальный процессор DSP, DSP Floating-Point 16Bit 57MHz 28.5MIPS 100Pin PQFP
TMS320C52PJ57
201 ₽
TMS320C52PJ57
1 498 ₽
Эиком
TMS320C52PJ57
1 648 ₽
TMS320C52PJ57
Pin100
Package TypePJ
Industry STD TermQFP
JEDEC CodeR-PQFP-G
Width (мм)14
Length (мм)20
Thickness (мм)2.7
Max Height (мм)3.1
RoHSНе совместим
  • Digital Monopulse Doppler Radar and DSP Teaching
    PDF, 119 Кб, Файл опубликован: 1 июл 1997
    In 1995 several teams of EFREI students submitted a project to the Texas Instruments DSP Challenge. This paper describes the adventure of one project which passed with success the European semi-finals to go and participate to the worldwide final in May, 1996 in ATLANTA.The winning project deals with the Digital Signal Processing (hardware and software) associated with a new class of a Digital
  • Improving 32-Channel DTMF Decoders in PBX Systems Using the TMS320C5x DSP
    PDF, 122 Кб, Файл опубликован: 1 июн 1996
    Using a DSP to perform multi-channel DTMF decoding can decrease PBX system cost while increasing system performance and flexibility. This document presents an improved technique for 32-channel DTMF decoding using the TMS320C5x 16-bit fixed-point DSP. The appendix contains the assembler source code for this application.
  • A PCMCIA TMS320 DSP MediaCard for Sound and Fax/Modem Applications
    PDF, 161 Кб, Файл опубликован: 1 мар 1995
    This document describes the system architecture of the TMS320 digital signal processor (DSP) PCMCIA media card and its operation. Operational examples are provided for setting up the DSP, for loading and executing single and multiple algorithms, and for resetting the DSP. An in-depth discussion of the common and attribute memory, bus arbitration, DSP/host communication and FPGA is provided.
  • Calculation Of TMS320C5x Power Dissipation
    PDF, 199 Кб, Файл опубликован: 1 апр 1993
    The power supply current requirements for the 16-bit fixed-point TMS320C5x digital signal processor (DSP) depend not only on the device functionality, but also on the system parameters. This document describes the techniques for analyzing the system and device operating current levels. Once these factors are determined the power dissipation can be calculated followed in turn by the device thermal
  • Telecommunications Applications With the TMS320C5x
    PDF, 1.6 Мб, Файл опубликован: 1 мар 1994
    This book provides an overview of the TMS320C5x 16-bit fixed-point digital signal processor (DSP) family and its use in telecommunication applications. Each section provides application specific information about the following topics: digital cell systems, speech synthesis, error-correction coding, base-band modulation and demodulation, equalization and channel estimation, speech and character rec
  • Use of the TMS320C5x Internal Oscillator With External Crystals or Resonators
    PDF, 169 Кб, Файл опубликован: 1 июл 1995
    The TMS320C5x high-speed 16-bit fixed-point DSP allows considerable flexibility to meet a wide range of clock requirements. This document provides information on crystal and ceramic resonators, their frequency characteristic, a background on oscillators, and the type of oscillator circuit to use on the TMS320C5x. Also included are design considerations for external components and solutions for com
  • Minimizing Quantization Effects Using the TMS320 DSP Family
    PDF, 268 Кб, Файл опубликован: 1 июл 1994
    Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
  • Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments TMS320C52PJ57
