Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS8320SKGD2 — Даташит
СерияADS8320-HT
МодельADS8320SKGD2
Высокотемпературный 16-разрядный высокоскоростной аналого-цифровой преобразователь с микровыборкой мощности от 2,7 до 5 В.
16-Bit, High-Speed, 2.7V to 5V Micro Power Sampling Analog-to-Digital Converter. datasheet
PDF, 337 Кб, Версия: B, Файл опубликован: 7 сен 2012
0-XCEPT от -55 до 210
Package TypeKGD
Package QTY10
# Input Channels1
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.25 В
Digital Supply(Min)2.7 В
INL(Max)2.1 +/-LSB
InterfaceSPI
Рабочий диапазон температурот -55 до 210 C
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
Power Consumption(Typ)1.95 mW
Reference ModeExt
Разрешение16 Bits
SFDR86 дБ
SNR88 дБ
Sample Rate (max)100kSPS SPS
RoHSSee ti.com
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS8320-HT (4)
  • Semiconductors > Space & High Reliability > Data Converter > Analog to Digital Converters
На английском языке: Datasheet Texas Instruments ADS8320SKGD2
Публикации по теме
