Datasheet Texas Instruments TMS320C10FNLR25 — Даташит
СерияTMS320C10
МодельTMS320C10FNLR25
Цифровой сигнальный процессор 44-PLCC
Digital Signal Processors datasheet
PDF, 1.8 Мб, Версия: C, Файл опубликован: 1 июл 1991
Цифровой сигнальный процессор DSP, DSP Fixed-Point 16Bit 25.6MHz 6.25MIPS 44Pin PLCC T/R
TMS320C10FNLR25
233 ₽
TMS320C10FNLR25
540 ₽
TMS320C10FNLR25
540 ₽
TMS320C10FNLR25
1 208 ₽
Pin444444
Package TypeFNFNFN
Industry STD TermPLCCPLCCPLCC
JEDEC CodeS-PQCC-JS-PQCC-JS-PQCC-J
Маркировка@1987 TITMS320C10FNL-25
Width (мм)16.5916.5916.59
Length (мм)16.5916.5916.59
Thickness (мм)4.064.064.06
Pitch (мм)1.271.271.27
Max Height (мм)4.574.574.57
RoHSНе совместим
  • TMS320C1x Evaluation Module Analog Interface
    PDF, 173 Кб, Файл опубликован: 1 янв 1993
    The TMS320C16 evaluation module (EVM) is used to evaluate the performance characteristics of the TMS320C1x 16-bit fixed-point digital signal processor (DSP). This document builds a supplemental analog interface board that provides the analog capabilities commonly used by the DSP chip. This detailed document includes the schematics, the parts list, the cable connections, the power requirements, and
  • Minimizing Quantization Effects Using the TMS320 DSP Family
    PDF, 268 Кб, Файл опубликован: 1 июл 1994
    Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
  • Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments TMS320C10FNLR25
