Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74LVC1GX04DBVR — Даташит
СерияSN74LVC1GX04
МодельSN74LVC1GX04DBVR
Драйвер кварцевого генератора 6-SOT-23 от -40 до 125
SN74LVC1GX04 Crystal Oscillator Driver datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 29 окт 2015
Pin66
Package TypeDBVDBV
Industry STD TermSOT-23SOT-23
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаCX45CX4R
Width (мм)1.61.6
Length (мм)2.92.9
Thickness (мм)1.21.2
Pitch (мм).95.95
Max Height (мм)1.451.45
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeOSCILLATOR INVERTER/BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power,Unbuffered output
Sub-FamilyInverting Buffer/Driver
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)7,4,3.7,7 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1GX04DBVR
