Datasheet Texas Instruments UC1846J/80364 — Даташит
| Серия | UC1846 |
| Модель | UC1846J/80364 |
ШИМ-контроллер токового режима 16-CDIP от -55 до 125
UCx846/7 Current Mode PWM Controller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 4 янв 2016
Купить UC1846J/80364 на РадиоЛоцман.Цены — от 783 до 1 344 ₽Преобразователь DC/DC, Current Mode PWM Controller 500mA 16Pin CDIP | |||
| UC1846J/80364 Texas Instruments | 783 ₽ | ||
| UC1846J/80364 Texas Instruments | 1 344 ₽ | ||
| UC1846J/80364 Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 16 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Width (мм) | 6.92 |
| Length (мм) | 19.56 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Control Method | Current |
| Duty Cycle(Max)(%) | 50 |
| Frequency(Max)(kHz) | 500 |
| Operating Temperature Range(C) | -55 to 125 |
| Package Group | CDIP |
| Package Size: mm2:W x L (PKG) | See datasheet (CDIP) |
| Rating | Military |
| Special Features | Error Amplifier Soft Start Synchronization Pin Multi-topology |
| Topology | Boost Flyback Forward Full-Bridge Half-Bridge Push-Pull |
| UVLO Thresholds On/Off(V) | 7.7/6.95 |
| Vin(Max)(V) | 40 |
| Vin(Min)(V) | 7 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Modeling Analysis and Compensation of the Current-Mode ConverterPDF, 189 Кб, Файл опубликован: 5 сен 1999
As current-mode conversion increases in popularity several peculiarities associated with fixed-frequency peak-current detecting schemes have surfaced. These include instability above 50% duty cycle a tendency towards subharmonic oscillation non-ideal loop response and an increased sensitivity to noise. This application note attempts to show that the performance of any current-mode converter c - DN-45 UC3846 UC3856 and UCC3806 Push Pull PWM Current Mode Control ICsPDF, 27 Кб, Файл опубликован: 5 сен 1999
The UC3856 is a pin-for-pin-compatible high-performance bipolar version of the industry standard UC3846. It can replace the UC3846 with few circuit modifications and it features increased speed higher gate-drive current and reduced propagation delays. The UCC3806 is a BiCMOS pin-for-pin compatible ultra-low-power version ideal for battery low-power and high-speed applications. The UCC3806 - U-93 A New Integrated Circuit for Current Mode ControlPDF, 411 Кб, Файл опубликован: 5 сен 1999
Advantages of current-mode control over conventional PWM approaches to switching power converters include automatic feed-forward automatic symmetry correction inherent current-limiting simple loop-compensation enhanced load-response and the capability for parallel operation. This application note introduces the first control integrated circuit specifically designed for this topology defines - DN-62 Switching Power Supply Topology Voltage Mode vs. Current ModePDF, 66 Кб, Файл опубликован: 5 сен 1999
This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UC1846 (8)
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
