Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74LVC1G04QDBVRQ1 — Даташит
СерияSN74LVC1G04-Q1
МодельSN74LVC1G04QDBVRQ1
Автомобильный каталог Одиночный инвертор 5-SOT-23 от -40 до 125
Single Inverter Gate, SN74LVC1G04-Q1 datasheet
PDF, 858 Кб, Версия: D, Файл опубликован: 3 янв 2013
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаC04O
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeINVERTER BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicInverting
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
RatingAutomotive
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,Small DPW package,low power
Sub-FamilyInverting Buffer/Driver
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)7.5,5.2,4.2,3.7 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G04-Q1 (2)
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G04QDBVRQ1
Публикации по теме
