Datasheet Texas Instruments SMJ320C26BGBM — Даташит
| Серия | SMJ320C26B |
| Модель | SMJ320C26BGBM |
Процессор цифровых сигналов 68-CPGA от -55 до 125
Datasheet
| SMJ320C26BGBM Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 68 | 68 |
| Package Type | GB | GB |
| Industry STD Term | CPGA | CPGA |
| JEDEC Code | S-CPGA-P | S-CPGA-P |
| Маркировка | SMJ320C26BGBM | 5962-8861903XA |
| Width (мм) | 24.38 | 24.38 |
| Length (мм) | 24.38 | 24.38 |
| Thickness (мм) | 2.03 | 2.03 |
| Pitch (мм) | 2.54 | 2.54 |
| Max Height (мм) | 3.62 | 3.62 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Engine Knock Detection Using Spectral Analysis With TMS320C25 or TMS320C30 DSPsPDF, 254 Кб, Файл опубликован: 1 янв 1995
An efficient method of detecting combustion engine knock is using spectral analysis. The detection process algorithm adapts to a no-knock reference at varying speeds and loads by using multiple frequencies. This document presents an problem overview current technology and two implementation examples are given to aid in the development of system specific hardware and software. The first system is - Minimizing Quantization Effects Using the TMS320 DSP FamilyPDF, 268 Кб, Файл опубликован: 1 июл 1994
Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how - Setting Up TMS320 DSP Interrupts in 'C'PDF, 168 Кб, Файл опубликован: 1 ноя 1994
Four steps are required to set the TMS320 DSP interrupts: create a interrupt service routine initialize the vector table and set the memory map enable the interrupts in the CPU and enable the interrupt sources. This document shows how to set the interrupts in C C callable assembly or in-line C. Sample C code segments are provided. The appendix gives complete examples for setting interrupt vec
Серия: SMJ320C26B (4)
- 5962-8861903XA 5962-8861903YA SMJ320C26BFDM SMJ320C26BGBM
- Semiconductors > Processors > Other Processors
