Datasheet Texas Instruments V62/04671-01XE — Даташит
СерияSN74LVTH125-EP
МодельV62/04671-01XE
Усовершенствованный продукт, 3,3 В, четырехкратные шинные буферы с выходами с 3 состояниями, 14-TSSOP от -40 до 85
SN74LVTH125-EP datasheet
PDF, 646 Кб, Файл опубликован: 7 ноя 2003
5 предложений от 5 поставщиков
Микросхема Логический чип, Enhanced Product 3.3V Abt Quadruple Bus Buffers With 3-State Outputs 14-TSSOP -40℃ to 85℃
V62/04671-01XE
77 ₽
V62/04671-01XE
ТаймЧипс
V62/04671-01XE
V62/04671-01XE
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаLH125EP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Bits4
Тип входаTTL
Тип выходаCMOS
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH125-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
V62/0467101XE, V62/04671 01XE
На английском языке: Datasheet Texas Instruments V62/04671-01XE
Публикации по теме
