Datasheet Texas Instruments INA2132UA/2K5E4 — Даташит
СерияINA2132
МодельINA2132UA/2K5E4
Двойной разностный усилитель малой мощности с одним питанием 14-SOIC от -40 до 85
Dual, Low Power, Single-Supply Difference Amplifier datasheet
PDF, 832 Кб, Файл опубликован: 27 сен 2000
Pin14
Package TypeD
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Approx. Price (US$)1.80 | 1ku
CMRR(Min)(dB)76
Common Mode Input High(Max)(V)28
Common Mode Input High(Min)(V)28
Common Mode Input Low(Min)(V)-15
Gain Drift(Max)(ppm/C)1
Gain Error (+/-)(Max)(%)0.075
Gain(Max)(V/V)1
Gain(Min)(V/V)1
Gain(V/V)1
Input Offset (+/-)(Max)(uV)250
Input Offset Drift (+/-)(Max)(uV/C)5
Iq(Typ)(mA)0.16
Number of Channels(#)2
Operating Temperature Range(C)-40 to 85
Package Size: mm2:W x L (PKG)14SOIC: 52 mm2: 6 x 8.65(SOIC)
Slew Rate(Typ)(V/us)0.1
Small Signal Bandwidth(Typ)(MHz)0.3
Vs(Max)(V)36
Vs(Min)(V)2.7
RoHSНе совместим
  • High-Voltage Signal Conditioning for Differential ADCs
    PDF, 125 Кб, Файл опубликован: 14 июн 2004
    Analog designers are frequently required to convert high-voltage signals to levels acceptable to low-voltage data converters with differential inputs. This paper describes solutions for this common task using modern amplifiers and typical power supplies. Three examples of conditioning В±10V bipolar signals for low-voltage analog-to-digital converters (ADCs) are shown: a single-supply design,
  • Semiconductors > Amplifiers > Special Function Amplifiers > Difference Amplifiers
На английском языке: Datasheet Texas Instruments INA2132UA/2K5E4
