Datasheet Texas Instruments 8410001DA — Даташит
СерияSN54HC393
Модель8410001DA
Двойные 4-битные двоичные счетчики 14-CFP от -55 до 125
SN54HC393, SN74HC393 datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 28 июл 2003
Pin1414
Package TypeWW
Industry STD TermCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-F
Package QTY11
CarrierTUBETUBE
МаркировкаSNJ54HC393W8410001DA
Width (мм)5.975.97
Length (мм)9.219.21
Thickness (мм)1.591.59
Pitch (мм)1.271.27
Max Height (мм)2.032.03
Bits4
F @ Nom Voltage(Max)28 Mhz
FunctionCounter
ICC @ Nom Voltage(Max)0.08 мА
Output Drive (IOL/IOH)(Max)5.2/-5.2 мА
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
ТипBinary
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)62 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments 8410001DA
