Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74CBTK32245ZKER — Даташит
СерияSN74CBTK32245
МодельSN74CBTK32245ZKER
32-разрядный переключатель шины на полевом транзисторе с активной схемой понижения напряжения с ограничением 96-LFBGA от -40 до 85
SN74CBTK32245 datasheet
PDF, 738 Кб, Версия: E, Файл опубликован: 25 сен 2003
Pin96
Package TypeZKE
Industry STD TermBGA MICROSTAR
JEDEC CodeR-PBGA-N
Package QTY1000
МаркировкаKT245
Width (мм)5.5
Length (мм)13.5
Thickness (мм).85
Pitch (мм).8
Max Height (мм)1.4
Additional FeaturesPowered off protection,-2V undershoot protection
Полоса частот200 МГц
Configuration1:1 SPST
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)5.5 пФ
Количество каналов32
OFF-state leakage current(Max)5 мкА
ON-state leakage current(Max)5 мкА
Package GroupLFBGA
Package Size: mm2:W x L96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA) PKG
Ron(Max)20 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)20 uA
Supply Range5.5 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)4 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
Серия: SN74CBTK32245 (1)
  • SN74CBTK32245ZKER
На английском языке: Datasheet Texas Instruments SN74CBTK32245ZKER
