Datasheet Texas Instruments VCA2613Y/2KG4 — Даташит
СерияVCA2613
МодельVCA2613Y/2KG4
Двойной усилитель с переменным коэффициентом усиления и малошумящим предусилителем 48-TQFP от -40 до 85
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
BW @ Acl(MHz)40
Max Gain(dB)45
Number of Channels(#)2
Operating Temperature Range(C)-40 to 85
PGA/VGAVGA
Package GroupTQFP
Package Size: mm2:W x L (PKG)48TQFP: 81 mm2: 9 x 9(TQFP)
Slew Rate(Typ)(V/us)300
Vs(Max)(V)5.25
Vs(Min)(V)4.75
RoHSНе совместим
  • Evaluation Modules & Boards: VCA2611EVM
    VCA2611 Evaluation Module
  • Evaluation Modules & Boards: VCA2613EVM
    VCA2613 Evaluation Module
  • Dual-Channel VCAs: Methods for Powering Down One Channel
    PDF, 102 Кб, Файл опубликован: 11 июн 2004
    Texas Instruments offers several product groups of highly-integrated voltage-controlled amplifiers (VCAs) including the VCA2611/12/13/16 and the VCA2614/18/19. Both the VCA2611 and the VCA2614 families feature two channels, either of which can be powered while powering down the other. This application note outlines two possible approaches to this question and describes the steps needed to assure t
Серия: VCA2613 (3)
  • Semiconductors > Amplifiers > Programmable & Variable Gain Amplifiers (PGA/VGA)
На английском языке: Datasheet Texas Instruments VCA2613Y/2KG4
