Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74LVC1G04DCKRG4 — Даташит
СерияSN74LVC1G04
МодельSN74LVC1G04DCKRG4
Одиночный инвертор 5-SC70 от -40 до 125
SN74LVC1G04 Single Inverter Gate datasheet
PDF, 1.6 Мб, Версия: AD, Файл опубликован: 23 апр 2014
Pin5555555
Package TypeDCKDCKDCKDCKDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70SOT-SC70SOT-SC70SOT-SC70SOT-SC70
JEDEC CodeR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-G
Package QTY3000300030003000300030003000
CarrierLARGE T&RLARGE T&RLARGE T&RLARGE T&RLARGE T&RLARGE T&RLARGE T&R
МаркировкаCCHCCSCCPCCFCCKCCRCC5
Width (мм)1.251.251.251.251.251.251.25
Length (мм)2222222
Thickness (мм).9.9.9.9.9.9.9
Pitch (мм).65.65.65.65.65.65.65
Max Height (мм)1.11.11.11.11.11.11.1
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачать
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeINVERTER BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicInverting
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,Small DPW package,low power
Sub-FamilyInverting Buffer/Driver
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)7.5,5.2,4.2,3.7 нс
  • Evaluation Modules & Boards: OPA547EVM
    OPA547 Evaluation Module
  • Evaluation Modules & Boards: EVMX777LCDTS-V1-0
    1280 X 800 Display and Touchscreen Daughter Board
  • Evaluation Modules & Boards: PP-SALB2-EVM
    Smart Amplifier Speaker Characterization Board Evaluation Module
  • Evaluation Modules & Boards: DLPLCR4500EVM
    DLPВ® LightCrafterВ™ 4500
  • Evaluation Modules & Boards: EVMX777BG-01-00-00
    J6Entry, RSP and TDA2E-17 CPU Board Evaluation Module
  • Evaluation Modules & Boards: TMDXEVM388
    DM388 DaVinci Digital Media Processor Evaluation Module
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • Evaluation Modules & Boards: EVMX777G-01-20-00
    J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
  • Designing and Manufacturing with TI's X2SON Packages
    PDF, 134 Кб, Файл опубликован: 23 авг 2017
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G04DCKRG4
