Datasheet Texas Instruments CD54HCT27F3A — Даташит
Серия | CD54HCT27 |
Модель | CD54HCT27F3A |
Высокоскоростная логика КМОП, тройная, 3 входа, вентили ИЛИ-НЕ, 14-CDIP, от -55 до 125
CD54HC27, CD74HC27, CD54HCT27, CD74HCT27 datasheet
PDF, 928 Кб, Версия: C, Файл опубликован: 21 авг 2003
![]() 13 предложений от 12 поставщиков Микросхема Логический чип, NOR Gate 3Element 3IN CMOS 14Pin CDIP Tube | |||
CD54HCT27F3A Texas Instruments | 979 ₽ | ||
CD54HCT27F3A Harris | по запросу | ||
Pin | 14 | 14 |
Package Type | J | J |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | CD54HCT27F3A | 5962-8970301CA |
Width (мм) | 6.67 | 6.67 |
Length (мм) | 19.56 | 19.56 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
Bits | 3 |
F @ Nom Voltage(Max) | 25 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | 4/-4 мА |
Тип выхода | CMOS |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | HCT |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
tpd @ Nom Voltage(Max) | 35 нс |
RoHS | See ti.com |
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HCT27 (2)
- 5962-8970301CA CD54HCT27F3A
- Semiconductors > Space & High Reliability > Logic Products > Gate Products
