Datasheet Texas Instruments CD54HC4046AF3A — Даташит
СерияCD54HC4046A
МодельCD54HC4046AF3A
Высокоскоростная КМОП-логика с фазовой автоподстройкой частоты и ГУН 16-CDIP от -55 до 125
CD54HC4046A, CD74HC4046A, CD54HCT4046A, CD74HCT4046A datasheet
PDF, 833 Кб, Версия: J, Файл опубликован: 21 ноя 2003
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
Маркировка5962-8960901EACD54HC4046AF3A
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Bits1
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.08 мА
Тип входаCMOS
Output Drive (IOL/IOH)(Max)5.2/-5.2 мА
Тип выходаCMOS
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)64 нс
RoHSSee ti.com
  • Implementation of FSK Modulation and Demodulation using CD74HC4046A
    PDF, 1.3 Мб, Файл опубликован: 25 ноя 2013
  • CMOS Phase-Locked-Loop Applications (Rev. B)
    PDF, 687 Кб, Версия: B, Файл опубликован: 19 сен 2002
    Applications of the HC/HCT4046A phase-locked loop (PLL) and HC/HCT7046A PLL with lock detection are provided including design examples with calculated and measured results. Features of these devices relative to phase comparators lock indicators voltage-controlled oscillators (VCOs) and filter design are presented.
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC4046A (3)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Phase-Locked-Loop (PLL)Products/Oscillators
На английском языке: Datasheet Texas Instruments CD54HC4046AF3A
