Datasheet Texas Instruments SN74CBT16209ADGVR — Даташит
СерияSN74CBT16209A
МодельSN74CBT16209ADGVR
18-битные коммутаторы шины Exchange на полевых транзисторах 48-TVSOP от -40 до 85
SN54CBT16209, SN74CBT16209A datasheet
PDF, 760 Кб, Версия: O, Файл опубликован: 9 ноя 2004
Pin48
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаCY209A
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Полоса частот200 МГц
Configurationcrosspoint/exchange
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)7.5 пФ
Количество каналов18
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)1 мкА
Package GroupTVSOP
Package Size: mm2:W x L48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) PKG
Ron(Max)20 Ohms
Ron(Typ)4 Ohms
Supply Current(Max)3 uA
Supply Range5.5 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)4 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
На английском языке: Datasheet Texas Instruments SN74CBT16209ADGVR
