Datasheet Texas Instruments SN74CBT3253DBQRG4 — Даташит
СерияSN74CBT3253
МодельSN74CBT3253DBQRG4
Двойной мультиплексор/демультиплексор на полевых транзисторах 1 из 4 16-SSOP от -40 до 85
SN74CBT3253 datasheet
PDF, 1.4 Мб, Версия: O, Файл опубликован: 15 янв 2004
АЦП азиатских производителей
Pin16
Package TypeDBQ
Industry STD TermSSOP
Package QTY2500
МаркировкаCU253
Width (мм)3.9
Length (мм)4.9
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
Полоса частот200 МГц
Bandwidth(Max)200 МГц
Configuration4:1
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)4 пФ
Количество каналов2
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)1 мкА
Package GroupSSOP
Package Size: mm2:W x L16SSOP: 19 mm2: 3.9 x 4.9(SSOP) PKG
Ron(Max)15 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)3 uA
Supply Range5.5 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)4 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
На английском языке: Datasheet Texas Instruments SN74CBT3253DBQRG4
